Spring loaded? That's why i couldn't turn in back in. Thanks!
So the search will go on...
Timing chain seems to be ok, that IP-pump gear is turning, when the starter turns.
I guess i should list the things i already checked, maybe there is something i missed?
Batteries were old -> installed two new 6T batteries (950CCA).
27MT starter turned 100-200rpm -> installed new 27MT starter, turns 400-500rpm.
Glowplugs were old -> installed new Bosch Duratherms, all 8 are measured at 1ohm and getting 12V if i push the button.
Fuel Filter (spin-on, installed last year) is good, output flows a nice stream, when starter turns. Because of this, the lift pump is also working as it should, right?
Check-valve was clogged last year, so i installed a larger one (1/4" inner diameter with 6psi opening pressure). Works great, but i pulled it out yesterday and tried out a regular hose fitting without valve.
Fuel shutoff solenoid, cold start solenoid and cold start idle solenoid are getting 12V if i switch the key to ignition on. The shutoff solenoid clicks pretty loud.
Pulled the IP-cover, pump is filled with fuel. Can't see anything damaged, everything looks straight and is moving without force.
Checked the fuel shutoff solenoid on my workbench, it is working with external 12V.
It just won't start.
Engine is turning over, but no smoke from exhaust.
Everything started, after i took out the CDR valve to repair the "double-elbow" rubber-thingy with some selfwelding siliconetape. The preowner ripped it apart with the hose-clamps, so ist was dripping oil. I reinstalled anything, started right up, was running 10 seconds, shutoff by itself and never started again.
Anyone has another idea? I really need to get it running, it is my daily-driver/workhorse and i don't like to drive the vette on rainy days, like last week.
BTW: Just an info, if my starter-rpms seem a little off: My tach is showing 700-800rpm at idle and 3600rpm at 55mph on stock size tires with 4.56s. So maybe it's not working properly.
