IP problem with my new Deuce...need advice
acesneights1
24
20
CT
well I decided to spend Memorial Day trying to revive a Steel Soldier.
The motor looks pretty bad. At this point I don't think it's worth saving. I have no issue dropping in one liner ans piston. I have worked for cheap ass dirt merchants most of my life as a mechanic and many times had a MAck or a Detroit drop a slug and fix it by just replacing that one. In this case though what bothers me right off the bat is the handful of shratnel that was laying in the #5 Exhaust port. That means it went through the turbo as well. Also the piston is destroyed and there is a huge gap between the piston and cyl wall. To be honest I am not sure what happened here but I suspect it was like this when I bought it. I doubt the few mins I ran it choked off did this much damage although there was no oil on the side of the motor when I bought the truck, not to say he didn't clean it up.
Anyway the head took a good beating and I see what looks like a tiny crack between the valves so at min I am looking at a used head, a piston and liner, full gasket set and I have a broken stud in the turbo and one broken ex manifold bolt.
That adds up to probably 800-1,000 worth of parts alone plus all that metal is floating around in the motor.
Also a word to anyone disassembling one. When you go to pull the pushrods out..BE CAREFUL !! The will sort of "stick" to the tappets and the tappet will come up with it and drop in the side of the motor...ask me how I know. I only lost one and I think I can get it back in with a magnet otherwise the side cover now has to come off. After that happened I lifted each push rod just a little bit and wiggled it under I felt the tappet drop down.
It doesn't matter now since I will scrap the motor now anyway. I am really curious to know what happened ? I may drop the pan anyway. See what the shratnel looks like in the pan.
Also note in the pics...Why Snap on tools are worth the money vs a chinise POS extension.
Also a quick homemade wrench to get the headbolts off the drivers side. No way that cheesy little ocket they sell would loosen these. I bent my bent wrench trying to get them loose but they finally gave.
Also look how bad the ridge is ? And the gap between the cyl and piston ? Did the liner come apart ?? How could a ridge like that happen so fast ?The other cyls are fine.
acesneights1
24
20
CT
So now the question is...used Multifuel or just do a 5.9 Cummins ? I wonder how guys made n air compressor work with the Cummins. Does anyone know if there is an adapter to bolt the Cummins to the Deuce tranny ?
acesneights1
24
20
CT
You know that pic of the ridge shows it better than I could see working on it. I wonder if that is smashed up shratnel stuck to the top of the liner ???
welldigger
Benton LA
If your willing to do it and have the money a 5.9 would be the way to go. There is an air compressor that bolts to the cummins so no worries there. Bolting a cummins to a Spicer has been done but I'm not sure what all is involved. Contact peashooter. He knows a guy who put an eaton 6 speed into an a3. If you have the money that's the way to go.
acesneights1
24
20
CT
If the block doesn't have a hole in it don't scrap it. Still plenty of good parts there.
No I will keep it, I mean by srcap that I am not going to fix this motor. There is just too much unaccounted for shratnel. The turbo could be damaged as well so a used complete motor at this point seems to be the way to go.
gimpyrobb
dumpsterlandingfromorbit!
27,787
778
Cincy Ohio
I'd say 6bt or a 466dt. The 6bt has been done and documented, I haven't seen a 466dt documented. Both solid motors.
acesneights1
24
20
CT
Can you point me to a good thread on the 6bt ?
Also the crate motors on GL sometimes that look brand new in the crate ? Are they any good ?
welldigger
Benton LA
My big thing about keeping the LDT is the multifuel capability. It is a nice feature in a SHTF scenario.
A 6bt will run on just about the same things as a multifuel with the right injector pump. I believe it is the "p" pump. I could be wrong on the model. There is almost nothing special about the multifuel. It's just a high compression diesel.
rustystud
3,374
Woodinville, Washington
Looks like your engine ate something in that cylinder (loose bolt in the manifold ? ). Also the bell housings on the deuce are SAE pattern so you should have no problem adapting up to the tranny. Of course if your going with a new Cummins why not go with a newer tranny with an overdrive that can actually do something ?
acesneights1
24
20
CT
On my current budget I think another LDT is in order.
