gimpyrobb
dumpsterlandingfromorbit!
- 27,791
- 791
- 113
- Cincy Ohio
Every little bit is one step closer to running. Good luck.
I searched the -12 and -34 manuals. I couldn't find "one lobe is pointed out and 45 degrees down." Where does it say that? Some other manual???Lots of developments.
BLUF:, I had the right shims, and I'm pretty sure I'm 180-bass-ackwards from correct timing.
I measured (4 times) the distance from the mounting surface to that flat machined surface on the cam, and after doing the math, came out to .014. so I measured the shims, and lo an behold I had a few different sizes to make the .014 I needed. then, to make it even better, I found where it was marked on the block, above where the IP mounts, where "014" is stamped clearly into the block. Nice.
Way to go!!!
So on to flow timing. I aligned the PC mark with the timing tab, the rockers were loose on the valve tips like someone else said, and according to the manual, "one lobe is pointed out and 45 degrees down." which it appeared to be. which one, you ask? not the valves corresponding to cylinder #1, I figured out later. so I realized that my PC mark was lining up halfway through the injection cycle on #1, or during part of #3. so I'm more like 90 degrees out. just enough to be annoying. so I'm gonna set it up again and try to crank tomorrow. just wanted to share the info. I felt a little defeated at first, but now that I know what I did wrong, I know where to start tomorrow.
Later,
Josh
that makes me say "EUREKA!!" and start peeing excellence. however it happens, I'm getting more motivated by moment.Either cylinder one or four rocker arms should be loose. The PC mark should be very close to the pointer. There is some slop in the gears so it won't be perfect.
Make sure you -> "Set throttle lever on injection pump to wide open or up position (compress stop solenoid plunger spring or remove stop solenoid assembly)." That is really important.I used the -34 manual AND the 7-page bulletin from AMBAC someone posted up earlier; the latter is where the lobes pointing different directions came from.
Ok, thanks for that intel.
and yes, the rockers were loose and the timing pointer was on PC when i mounted it. i used a drill bit (the shank, not the fluted portion) as my "rod" to hold the pump gear still. I think the flywheel is properly mounted, but what causes me to suspect that I'm significantly off-time is that when i do what the manual says, I "move the blower wheel counterclockwise about 1-inch, then begin turning the blower wheel clockwise until fuel stops flowing from the #1 fuel line" the flywheel reaches "PC" when the #3 hole is pushing fuel. is there more than one place in the combustion cycle where both rockers are loose? if not, then I may not be in terrible shape.
They will only be loose during compression and power strokes. (Only once per two revolutions) The PC mark will put cylinders 1 and 4 near TDC so only one will have both rockers loose. (and we all agree cylinder #1 is closest to the blower end right?)
also, do I plug the return line and the other three cylinders? I'm using an IP originally from an 002A, so I just left the two caps on. I'm thinking maybe I cap off the return port and the #3 cylinder port and double check my timing position.
Now that makes me wonder.... If the two orignal caps are still on the pump me thinks your #3 is actually #4. The firing order is 1-2-4-3. Are you counting the ports 1-2-3-4?
I'm closer, just not close enough to see where i need to be headed. I'm going to put on my coveralls in a minute... maybe the horseheads on my twin Cav shields will whisper nuggets of wisdom in my ear. or maybe the generator will see the similar color green in the picklesuit's fabric and think we're kindred spirits. Or maybe one of you guys will come up with another pearl like this one:
While there are a lot of similarities between the Civy Onan and the MEP-Onan, There are some very significant differences.yes, they tell me I'm probably 180 out, so I'm starting over using your pointers. also, I adjusted the timing pointer on the flywheel (according o the figure in the manual) and I also noticed a pointer on the blower wheel end. the AMBAC bulletin shows this pointer as the one to use. thoughts?
I used the one on the flywheel.
is it possible that my blower and flywheel aren't aligned?
Don't know... Never looked
I've been using the flywheel end to check for "PC". I'll be checking for markings on the blower wheel momentarily, once I mark where "PC" is on the side to make it easier to see when it comes around. and you might be right about #1 and 4 versus #1 and 3.... I'm counting 1-3 and 2-4 like a chevrolet... sumbitch, you ARE right... it's #1 and #4, not 3 like i previously posted. k. back to tinkering.
PM inbound.
