IP
Iceman3005
97
Holt, MI
6.5 L DB2 MARINE Fuel Injection Pump, Will this pump work in a 6.2?
would this even be recommended? Reason I ask my IP is starting to go, I can get the marine IP for not much more than a 6.2 IP.
3,164
I'd say it might fit, but would be incorrect for the engine. If the truck isn't your daily driver, pull the pump and have it rebuilt, or, see if the ADS shop has an exchange.
Iceman3005
97
Holt, MI
I have heard of guys putting these on a 6.2 but not sure if there a direct bolt up or need some machine work? I want too increase the power, If I do this I probably will install marine injectors, turbo, girdle, arp studs, and fire ring the head. Not sure if I want too go this route anyway.
dstang97
33
Clover, SC
If you are gonna turbo find a 4911 pump. off a 93 diesel. Then get 6.5 injectors, and max out the pump, that is about it.
