jj
- 18
- 0
- Kutztown,PA
Yes, that is a fair assumption. Since the DOT5 is not hydr, uh, doesn't absorb water, it can tolerate sitting around much better than DOT3. The DOT3 fluid mixes with moisture that gets into the system then causes corrosion. When the moving parts move they sieze on the corrosion, and you get frozen wheel cylinders and calipers. Since the moisture that gets into the DOT5 doesn't mix, it just settles in the low points of the system. Yes it will cause corrosion there, but it doesn't seem to be as big a problem. I think because the "low points" tend not to be the moving parts.
