Is my tranny shot ?
DC9Driver
Ohio
New GP 1097A2 was delivered this week and it will only drive in L. Checked all the fluids they are fine , It tries to move in H and HL but doesn’t
I think I know the answer……..but hoping for a miracle.
TOBASH
3,946
Brooklyn, NY
Are you talking transmission or transfer case? Tranny has a low BUT only xfer case has HL and H and L.
Mogman
10,495
Papalote, TX
I think what the OP is saying is the transmission is slipping to the point it will only move the vehicle in low range because of the ratio it makes it easier to move the vehicle, does not sound good, what does the trans fluid look like bright shinny red?
As others have said inspect all the half shafts etc, but even with a bad half shaft it will pull in HL as well as L
If all that checks out then it is time to drop the pan and see what the sediment looks like.
DC9Driver
Ohio
Checked the transmission fluid with it running after driving back and forth in the driveway.
It was low so I added a quart. No change
Fluid looks ok (nice red color) on the dipstick doesn’t look burnt
@Mogman you are correct it only moves in Low range on the transfer case handle
H or HL it acts like it wants to move but nothing
Mogman
10,495
Papalote, TX
If it were me I would drop the pan with the intention of changing the fluid and filter, try not to disturb the sediment in the bottom of the pan so I could inspect it and I would pull the fill plug on the transfer case to see if it was over full if not done already, if it is over full it probably has a bad cooling loop in the T/C and if over full I would change all the fluids in the gear hubs and differential right away, actually I would change all the fluids anyway just cuz.
You never said if it was still low or not after the quart, a quart low can damage a transmission if run long like that, there is quite a bit of fluid in the transmission but most of it is in circulation during operation and not really that much in the pan.
DC9Driver
Ohio
After I added the quart of fluid it stabilized just below the hash marks on the dipstick when I checked it while running. Definitely going to change all the fluids and filters regardless.
