Is there a high-beam indicator light on dash?
Rgdl
Winnipeg, Manitoba, Canada
Is there a high-beam indicator light on dash? This is one of the items that failed the safety inspection on my M818.
If there is one - where on the dash is it located?
Ferroequinologist
Resident railroad expert
4,812
748
Liberty Hill, SC
My XM818 has the tachograph on it, and the high beam is next to the lower right edge, say the 4 oclock position. It is just a tiny red dot- might be burned out (same bulb as the gauge lights) or it is just hard to see when there is any light out. Go out at night and check.
If you have a seperate tach and speedo, it should be in the lower left corner of the gauge panel.
ida34
36
Dexter, MI
One of the dash bulbs has a small diameter red spot in the center. That is the high beam indicator. Download the manual from the resource section and it will have a diagram of everything on the dash.
