goldneagle
- 858
- 113
- Slidell, LA
I bought MC-2A diesel operated air compressor from Eglin AFB. I got it running ok but it looses oil pressure after about 20 minutes of running. When you first start it the oil pressure goes up to 55 PSI but it then slowly drops to 25 PSI and lower after running for about 20 minutes or so. The unit has a Deutz F1L208D air cooled diesel. It shares the oil with a rotary compressor. The oil is cooled by a OIL cooler radiator with a large electric fan.
I have already replaced the filters and has new 30 weight oil in her. Any ideas why the drop in oil pressure? It is also effecting the air pressure coming from the air compressor. As the oil pressure drops you get less and less air pressure produced! Any idea what might be causing this?
