spankybear
- 910
- 93
- WA
One for like rebuilding the trans. I have looked in the TMs and I am not finding what I am looking for.
spankybear, I believe coachgeo is most likely correct.my understanding was when things got to that level..... engines and tranny's were just renewed...aka jobbed out to a non military business who earned a govt. contract to do the work. There may be no military manual for that level of work...... cause military did not do the work.
This process was part of the re-working of how all things are done compared to motor pool of the past where military did it all. Change started in late 80's early 90's?
Could be wrong.
spankybear,I know that that a transmission repair/rebuild is more likely a depot repair and would most likely be a contractor. I am looking for an Allison manual. NDT posted the Allison manual for the trans ECU and was hoping someone had a lead on the trans itself. I am not going to do anything major but replace the input seal and bushing. I want to know the torque values of the stuff I will be taking off to get to the bushing. I want to do this right the first time.
I have to ask about your M936... So there are lights that are not working on rotating platform? There must be some type of slip ring assembly. Some are rebuildable and some are not. I would think the corrosion would be more the issue.. But I have seem the wrecker so I not 100% sure. Post a picture of what you have.
Done. I decided it made more sense to edit my previous post and put the numbers below the picture. (Post #9)can you post the part numbers?
Hi spankybear,I have to asks can it swivel 360º+? Look like there are 3 wires going though. I would check continuity of all 3 wires.
Looks like it's fig 496. I come up with a US TACOM part number of 11669352 and a NSN of 4810-01-106-2062
Looks like your part may have been made by Hydromotion and their part number maybe 03-011-001 .
There are also a couple of other companies that made that part. Below is a link with all of the companies. Also a link for Hydromotion. You maybe able to get some help from them... maybe not... I don't know.
Custom Hydraulic Cylinder Manufacturing | Industrial Hydraulic Components
Texas Hydraulics, Inc is a leading manufacturer of custom welded hydraulic cylinders in the United States.www.hydromotion.com
