Is there a syncronized tranny available?
reamer
Ashford, CT
Is there a syncronized tranny available that will bolt up to a 1943 DOdge 230 Flathead. This is in a 3/4 ton command car. I would like to get it to shift easier.
Thanks
reamer
SETOYOTA
451
georgia
A 3/4 ton command car is a rare vehicle IMHO it would ruin it to put in a different tranny. do you know how to double clutch? That is all that needs to be done to shift smoothly.
nattieleather
149
Cleveland, OH
It would have to be one out of a M37B1 and even then you need to double clutch... :) You'de have to convert to a modern transmission which would mean some fabricating to make it work. I don't have a model number for you though sorry.
zak
-4
Ortonville, Mi
The Canadian M37 Trans is synchronized 2nd thru 4th and should bolt up. A larger clutch is used but some flywheels where drilled for both sizes. But good luck on finding the trans , its kinda scarce. You may have to but the whole truck.
Bill W
47
Brooks,Ga
M-37 tranny will bolt up being both early m-37 and later B1 ( NP420 ) trannies were syncro'ed in 3rd & 4th gear however you'd probably have to cut the tranny floor pan to get the shift tower to fit and if it was mine I personally could not bring myself to do that, Half the fun of these old trucks is learning how to shift the old spur gear (Crashbox) trannies
Wolf.Dose
10
Boehl-Iggelheim, Germany
I think you should learn to shift and NOT ruin you commander.
However, if you will NOT learn it, the gear reatings of the T98 are the same as the Dodge ones from WW II. If you find a good T98 and a good mechanic and the bearings are the same size (which I do not know excactly) and the shifting plate fits to that, you have at least 3 syncronized gears.
Wolf
Milbikes
CT
Hey, another Command car in CT! I am in Canton. Any pics of yours?
On another note, I have a Russian BMW copy sidecar bike, and the transmission crunched like crazy when I shifted...and I have been riding BMW bikes for years. Another Ural rider described double clutching (A variation of it) and now I can shift the bike smooth as butter. Previous to that, I had NEVER heard of anyone double clutching a motorcycle. H.
reamer
Ashford, CT
Have not go t it yet, the wife is reeeeal bent out of shape! Still working on it though.
Where are you located?
I'd love to see it and how much work I have to replace the floor.
PM me if you can let me see it. I'm in Ashford
reamer
