Is this a 5 ton wheel?
1,168
900 series.
1,168
Not the same.
Look at the depth of the dish and the shape.
Definitely will not fit on an 800 series front (not sure about the rear).
This was recently discovered at the 2011 Ga rally. (If you would attend it, you would have known this too!):p
EMD567
Driver for the Ga Mafia
44
Aiken SC
Thats right- I spent the better part of an afternoon helping fix the problem after my buddy thought he had found the deal of the century. :mrgreen::jumping:
emr
24
landing , new jersey
,,, I have been using the same 10 lug rims for my ol 809 and 939 series, there are a few minor differences in looks in new versus old 10 lug standard rims, with that said, the tire the G177 was issued to the 939 series, but found there way onto other 809s in at least one instance a couple of times I saw up here on an 818 and wrecker over the years. the rim of the bridge truck are different though i believe. only things i know are what i have done, always willing to learn, but never seen a difference, I have had 30 rims loose over time 10 lug, but it is always possible i had all one type, but would have had to see that one... :beer:
jasonjc
283
Gravette Ar.
Well I just looked in those big paper things that have all the numbers and pic's and stuff. What are they called?:p Any way those thing say that the M809's (most) and the M939's(most) use the same wheel. The M821 and M812 use a diferent wheel.
1,168
Maybe Adam can get a part number off his rim, and we can figure out what exactly he has.
I hate to mis-inform/mis-lead anyone.
73m819
314
gainesville, ga.
SO does the 819
jasonjc
283
Gravette Ar.
M819 per MWO uses p/n12300571
M821 & M812 uses p/n 12356821
The rest of the M809's uses p/n 7389493 as do most of the M939's
The TM I looked at does not list a useable on code for the M819 at all:-?
73m819
314
gainesville, ga.
It will be where the tire/tube is as the 1200 that is only used on the 819, it calls for a rim specific to the 1200,
try the 260- 20p
1,168
The MWO for the M819 wheels is in, MWO 09-2320-260-30-1 It's for 3 wheel/tires. Fronts and a spare.
2530-01-112-2166 12300571
jasonjc
283
Gravette Ar.
TM 9-2320-260-24p-1 2003 does not show a useable on code in the front of the book for a M819 at all. But yes it is all list in the MWO. I've got some other "P's" for the M809's but have not looked in them.
