Is this leak bad? What is it? How to fix it? Newbie
wsucougarx
112
Washington State
Hello, I went and look at a bunch of trucks today. The best one as far as I could see was a particular truck. However, there appears to be a pretty good leak somewhere. I traced it to this part. Is this the steering box? Is it power steering? Is this an easy fix? Could the bolts be loose? How easy would it be to remove it, err or how hard? How easy would it be to replace? Sorry for all the questions. I'm new to M35's and will hopefully be a winner of one soon :lol:
Its definately not motor oil. It's very viscous...it is definately gear oil... Help
3,205
Not power steering unless it has air assist, a big air can on the tie rod. I think every deuce leaks at the steering box.. Check the LO for what goes in it.
DanMartin
17
Hillsboro, Oregon (USA)
Mine leaks in the same area...it's actually coming from either the injector pump or the compressor. On mine there is some leak on either the throttle or fuel shut-off levers (where they go into the IP assembly). Check for lose bolts.
Because it's in the blow-back area from the fan, it's hard to tell for sure.
I'm at wits end on finding my leak...I'm about to steam clean the engine and use dye in the oil and a black light to track it down.
m16ty
228
Dickson,TN
wsucougarx said:
Does anyone know what this is? Is it just a gear box? What's LO?
Yes, it has a worm gear in it with the steering wheel attached to on end and the steering arm comming out the side through the frame.
LO means "Lube order". LO 9-2320-209-12-1
1,827
If in fact its a leaky steering box, drain it and fill it with John Deere Cornhead grease.
3,205
Deuce_of_Spades said:
Dan, can you really do that? Or are you just pullin one over on us newbies? MR. CSI!
Yes you can, any oil, engine, trans, hydraulic, etc and you can dye coolant also.
scooter01922
42
Newbury, MA
Think i'm gonna do the same on mine with the dye, not only can ya do it but the stuff is easy to find just about anywhere. I know autozone carries the dye. You can get a kit that has the light as well as dyes for oil based systems or the AC. But personally i'm gonna go the cheap route and just grab a cheap blacklight at walmart and a refill bottle of the oil dye. For the 20-30 bucks it ought to cost i can find a few leaks without wasting an afternoon.
m16ty
228
Dickson,TN
wiggall, Go to the "resources" tab at the top of the page. Click on it and you will see "technical manuals" in the drop down box. Click on that and it will take you to all the manuals. The LO will be there.
jwaller
20
Columbia, SC
wsucougarx said:
So from what I am hearing, this is not a bad leak? I only need to drive 60 miles to get her home. Should do just fine
if thats the only leak you have then your good to go. you will soon have many more that will make this one look like the childs play that it is.
