Reworked LMTV
Expedition Campers Limited, LLC
- 1,571
- 1,217
- 113
- TN
Put Helium in the tires and you'll pass every timeCDL is required in many states over 26k, WI for example. Although mine is registered as an RV so don't need one.
In WI, they require it based on the highest of gvwr or actual weight. I was wayyyyy over so didn't want to tempt a grumpy cop.Put Helium in the tires and you'll pass every time![]()
Yeah - speedo stopped at 80. I saw 90 on the live data and that's as far as I pushed it. It was a bit terrifying. I typically just cruise at 60-70. It's happy there.Saw 90 huh? Wondered what those lights were in the sky... Now I know. Thought it was a drone![]()
Wow! What gear ratio are you running?Yeah - speedo stopped at 80. I saw 90 on the live data and that's as far as I pushed it. It was a bit terrifying. I typically just cruise at 60-70. It's happy there.
He is using ECO hubs. Instead of 2:1 reduction, his is 1:1.Wow! What gear ratio are you running?
Factory with ECO hubs.Wow! What gear ratio are you running?
Got to be Eco hubs!Wow! What gear ratio are you running?
...or at least ask what his fetish is for the LBCDWhen you get to 88 mph, you get to go back to the time that somebody at Stewart and Stevenson decided not to include locking differentials, and you get to knock some sense into him!
