gimpyrobb
dumpsterlandingfromorbit!
- 27,791
- 787
- 113
- Cincy Ohio
Happy to help.
Were gonna need pics now...
This LEDs were designed for use as underglow lights for cars and such, so I'm hoping to at lease get a couple years out of them.Those LED strips may or may not last outside on your truck. Have you tried sand blasting the acrylic? That ought to help with the diffusion. If that doesn't do the trick, you could apply a reflective foil on the back of the acrylic and try shining light through the edge of the material. This is how TV's and computers screens are lit.
Looking good sir! Every conceivable hitch including a goose neck ball I believe... wait is there no 1 7/8ths on there?The Air assisted Pintle hitch pulled 41,000 LBS on our last equipment move. View attachment 729923
Yes, the gooseneck ball is rated at 30K and sits at the same height as my pickups. The drop hitch is at the same height as my trucks too. I figure if I can hook up with them then i'd be able to kooh it up too. Kind of funny but I have a 8' hydraulic manlift trailer and pulled it with the m1088 and it looked really smallLooking good sir! Every conceivable hitch including a goose neck ball I believe... wait is there no 1 7/8ths on there?![]()
Just pull it and take ito a radiator shop. Not worth try a permanent field repair and springing a leak...... cooking that massively expensive twice over transmision...... I have an issue now, a piece of metal fell over at the shop and hit the auxiliary cooler next to the spare tire and put a small hole in it. Does any one have any experience with repairing radiators? What did you use? .....
