- 33
- 23
- 8
- Coronado, CA
Greetings LMTVers.
My current camper-van conversion for my 1079 highlighted the need for an additional seat up front (2 adults+two kids) and after many hours staring at it and searching for the simplest configuration and installation, I arrived at a solution which is two 2009-2014 Ford F150 center jump seat/consoles installed side by side.
These seats have some specific traits which were helpful to a simple installation:
1. Narrower than 18 inches - there is approx 36 inches between Driver and 'A' Driver seats
2. Integral seat belt.
3. No protrusions past frame bottom. - allows mounting flush to each other.
My 1079 has a gunners deck, so that added to the simplicity. You can simply remove the existing seat, attach 2-3 in steel angles to the gunner's deck and drill holes to match the seat frames. Then bolt the gunner's deck back in the truck and bolt the seats to the angle brackets.
One unforseen advantage of these particular seats is that the 3 adult configuration can still comfortably be accommodated by simply straddling the two seats and use the right shoulder belt in the left seat latch.
All of that and cup-holders too.
Forgive me - I didn't take progressive pictures of installation steps.
