militarysteel
- 1
- 0
- Southern Ohio
how many of you had issues with your air pac locking up on ya? we just when through 3 air packs, and the 3rd is not as bad, -- I'm thinking a lot of people have issues with these air packs.
Had that happen once. Rebuild took care of it.
It's the brake booster unit.Whats an air pack? Thanks Jim
Thank you very much for that tidbit!The lube oil is "hydraulic" or air tool oil equivalent to 10W engine oil in viscosity.
You may want to research this...here is one comment off a Donaldson filtration system promo (image below).I have a question/comment related to this topic. I have occasionally added a small amount of air tool oil directly into the intake for the air compressor. I literally put in a “handful” at a time. I pour some oil into the palm of my hand and then I carefully place my cupped hand under the intake tube/port on the air compressor while the engine is running. The oil is sucked up into the compressor.
I have done this in the past when I noticed the air governor “sticking” and cycling repeatedly. It quickly remedied the governor problem. Does anyone know of any detrimental effects of this method?
It would seem that this would add a measure of air tool oil to the entire system, including the air pak right? I guess if you use your air powered windshield wipers that some of the oil could be exhausted from the wiper motor.
What say y’all?
The reason you need to remove compressor crankcase oil from the air supply is it gets wet from the water in the hot compressed air, and emulsifies. It typically looks like mayonnaise in your water separator... not a good thing for the metal stuff down the air line.You may want to research this...here is one comment off a Donaldson filtration system promo (image below).
The oil in the airpak is eventually exhausted and will not effect other parts AFAIK.
-Especially true on the A3, where all of it gets pulled out by the air dryer, if it isn't clogged by all the excess oil.The reason you need to remove compressor crankcase oil from the air supply is it gets wet from the water in the hot compressed air, and emulsifies. It typically looks like mayonnaise in your water separator... not a good thing for the metal stuff down the air line.
Because the compressor feeds the wet and dry air tanks from the top of the tank, and draws off the air from the top of the tank, any air tool oil you feed into the compressor's inlet will get trapped by the air tanks long before it can find its way to the airpack. He really needs to feed the oil directly into the airpack's air inlet.
-Chuck
