Just another bobbed m35
thebigpig
maine
Well every one I've been working oh this truck for a little over a year now, I'm not entirely sure what model it began life as it was a long wheelbase double frame truck with alll the normal a2 stuff I've cut it down split the second rail off hung the front suspension out of a freightliner buss and stuck the axle back in with a Lincoln locker lots more pictures to get up to date coming soon
Sent from my SM-G930V using Tapatalk
1,178
Site rules request you include a state in your location and that you attach pictures(not link).
thebigpig
maine
I've spent some time searching for detailed information on welding the sprag clutch of a m35a2 but couldn't come up with any thing so I t just pulled it apart and here's what I decided to do
cattlerepairman
3,337
NORTH (Canada)
I have heard of mud boggers "welding the sprag" but at least in this post here, welding is strongly discouraged: https://www.steelsoldiers.com/threads/sprag-substitutes.1093/
The reason is that the sprag clutch is an overrun clutch, and the function depends on different rotation speed between front and back. That would make the vehicle drive-able with a welded sprag clutch only when a set of wheels can freely slip. So...probably not with 4 sets of chains on the tires...
This is also cited as an issue here: https://www.steelsoldiers.com/threads/t-case-question.18159/
Please share how this works out for you, interested to learn!
I am no expert either way, just sharing info.
thebigpig
maine
My only plans for this truck are offroad so it seems to work just fine it doesn't hop or slip the tires noticeably and short of rebuilding the sprag it was only 2wd I wouldn't recommend doing it for a street driven truck
