DSD277
- 7
- 18
- Arcadia,CA
PCRUZ,
Give yourself a raise! Your post and pic are worth 384 cents . x 192
That is the first pic of a 6x6 War Pig I’ve seen!
It’s obvious that the War Pigs are bases off M1081s and now confirmed, M1093s
The 6x6 War Pig build really makes it easier, the cab of the M1094 and M1093 are the same, and the whole idea of making a War Pig is that the seller told me that there is a lot of damage to the cab, mostly above the waistline, and since the only thing I need there is a windshield for the street.
The only need I had for a new cab was for a solid cab for a Camper build, so I am sitting pretty for the War Pig. The need now would be for a cargo bed, to get rid of the 3000+ lbs of dead weight of the dump bed instead of cutting off the sides of the dump bed.
Bikeman,
I didn’t see any indication of the truck being rolled….possibility a hard landing where the folding cab parts weren’t properly secured… but you sure are next door to the truck now…. You’re only 120ish miles from it…. Much closer than my 2600
Bikeman,
