Just Bought a wrecker!
Droppedadeuce
Setauket, NY
So Ive had my deuce for about 3 years now, and always wanted a wrecker. Saw one on craigslist and decided to buy. 1973 M543a2 LDS Needs a lot of work, mostly the cab and some rust repair. Brakes do not work, Pretty sure the master is at fault. The big problem is electrical. The master power switch, and light switch were removed, ie cut out. The headlights and markers have been cut or disconnected. I tried to install a master power switch and I get the starter/lift pump to go on, but no air buzzer or gauges via the switch. However if I apply 24 volts to either one directly they work. IS this the wrong master power switch? It came with the truck. It's a dpst switch.
Thanks ahead of time.
Christian
catskillpond
wurtsboro ny
Your going to have to take your time ours is a 1970 and 50% of the wiring was rotted check by the circuit breakers as far as the brakes pull the wheels and replace all the lines they are probably rotted at the mounting points i believe the master switch on wreckers have four pins. Good luck
just a note I helped a buddy out his had the protective control box it was 543a2 and the power wire for the box rotted out that came from the battery switch repaired that and most everything worked.
ThatXJGuy
Riverton, Wy
Its been my experience with all 3 trucks I have bought that have been sitting that the master was empty and so were half of the lines but a good filling and bleeding made them perfect again. Two of the three trucks also required at least some line replacement but nothing else. Good luck with the truck, surely a good time ahead for ya.
NDT
6,147
Camp Wood/LC, TX
Congrats on the wrecker purchase. The good thing about a multifuel 5 ton is that the wiring is nearly the same as a deuce. You will need to carefully determine the number tags on the wires and insert the proper wires into the ignition switch. Follow the wiring diagram in the TM. Tape up the harness as best you can if you have frayed spots.
SteveKuhn
Hasbrouck Heights NJ
I suspect you found this out in The Islips, and the front-passenger tool box lid is bent, missing half of the driver's-rear outrigger. Starts with a hot wire. If so, I'm very glad it found a home. TPK and I spent a few hours there with it last weekend, but it came to pass that he needed to pass.. There is a lot of work to do in the truck but it should be both fun and rewarding.
If I'm right, you might want to link to the original thread in yours so that some additional context is available to help you out.
Steve
wreckerman893
Possum Connoisseur
15,618
2,013
Check the hydraulic hoses before you fill that large tank. And be prepared to take out a loan to do all of them.
On my M816 money pit the estimate to do all the hoses was north of 2K.
They are a real bit*h kitty to change out inside the control cab. If I remember correctly there is no access panel on the back of the old wreckers (the M936 has them) and unless you have three hands and are 3 feet tall getting to them will be a exercise in frustration.
Good luck and post pics,
