galeo7171
- 0
- 16
- Cumming, Ga
I just brought home my 86 m1009 from Ft. Jackson, SC. After a new battery it started right up! I have found two leaks so far.
The first leak is easy I think. Its leaking transmission fluid out the output shaft of the transfer case. The fluid gathers up on the u joint and drips down. I'm assuming all it needs is a new seal?
The second leak might take some time to fix. When the truck isn't running, diesel gathers on the oil pan and drops down. It looks like its coming from the passenger side, as I can see diesel on the starter. When the truck is running the diesel doesn't leak. I've done searches here but haven't come up with a real good explanation, of course I've been busy with work so I might just be missing the correct information.
