kats tank heater
topgun217
The Northern Border of Ohio
Has anyone installed a Katz circulation tank heater in their M1009? Can it be done correctly? I purchased one of these units and it is not working properly. If anyone has any input that would be great a pic of your installation would be better yet. Thanks in advance yellas.
1,172
I would contact the manufacturer for installation information.
acesneights1
21
20
CT
google five star manufacturing but I can tell you my experience with their customer service was not good but I do believe the manuals are online.
swbradley1
Modertator
1,651
Dayton, OH
When both my Kats heaters failed I called them. They put me right to their tech support and the guy said the thermostat may have failed.
Now, if I want anything to start I have heaters that I can plug into an outlet and point them at the trucks or backhoe. Mine are inside so I don't have to worry about wind.
dependable
187
Tisbury, Massachusetts
Hear you go.
This is not installed per instructions. Use at own risk. Works well for me. This is an older Kats tank heater form my plow truck 1008 which was retired due to rust. Recently put it in 1008 I am using this winter. Installed the way it was on plow truck when I bought it years ago.
Correct installation involves a Y connector to plug tap from water jacket on block or fitting on lower radiator hose.
One hose to inlet on crossover as pictured, one to heater core on fire wall. Note vertical position of heater. Run to bleed after installation.
This gets motor warm much faster than freeze plug type & probably creates hot spots. I always unplug and wait for engine heat to equalize a few minutes before starting.
