I have an M998 (rebuilt in 2005) with KDS smart start box. The wait light does not come on, fuel gauge isn't work but all other gauges seem to work fine. I can get it to start with starting fluid and it runs fine. I opened the box and see what appears to be a burned diode (see picture). I tested with an ohm meter and get 100ohms. No idea if that is good or bad though. I also tested a couple of the glow plugs and get no reading. Do I need a new EESS or is it just the bad glow plugs? I am worried if I just replace the glow plugs and there is some other issue it will just burn out the new ones.
Not sure if its related but with the key off when I connect/disconnect battery cables I get some light arcing. I do not see that with my M1097.
