No it's on 12v. I'm going to dig into the primer pump and see if it was just a tear in the hose from age. The gauge goes up to 120 and I know I'm put some pressure on it before the electric pump. Also going to look into a safety bypass to allow excess to go in the return like on hydraulic systems.Are you running the pump on 18v or 24? It would probably build 100 psi on 24v, or maybe just burn up...
I'm not all worried with it, it only does it when idling.FY, that waviness you see in your demo video is what you get when you use a progressive shutter camera versus a global shutter. t's hard to find cameras where that is specified...
You can try a foam/gell vibration mount to take out the vibration from the camera mount. Should improve the video quality.
It was the radio head, I had the sat radio antenna to low and it wasn't picking up so I was trying to tune the radio. I agree, not safe, I know the sequence to get the radio on, and put it in aux from memory, tuning it is harder since it doesn't have a seek function. The last couple trips I did around town I have made it a point to get the radio where I want it before I leave the driveway. Where the sat radio is I can push the preset buttons and know what station it is on.GoPros often have that jello issue. There's some software tool that will help reduce that effect when editing the video. Unfortunately I don't know what it's called, but I'm sure it can be found with a quick google search.
Also, you may want to consider moving the sat radio (I'm assuming that's what you were looking at) up higher on the dash or cab roof. You were looking down at it for a good while.
