Keith's M1078A1 Project Overland
Keith Knight
2,165
Wauchula, FL
My M1078A1 built in 2003 History, Purchased from GovPlanet September 2015 as a non runner all fluids drained, no batteries and a huge hole in the front left tire.
Picked it up from Hurlburt AFB, Florida.
I've been working on it ever since.
I'm late at starting this project thread but I wanted to have a single place to post the different things I've done to it, so I'll start posting current progress and past progress here and post links to my other threads.
To begin they through all the drain plugs away when they drained the fluids. Which is crazy because it leaked fluids everywhere hauling it home so it had to have been leaking fluids in the motor pool. So whats the reasoning for draining the fluids? Any way after purchasing new plugs, batteries and a used tire then filling it back up with fluids.
About 30 seconds of cranking it STARTED!!!! Surprisingly ran and drove great. Despite a few idiot lights on in the dash.
I'm along ways into the build now so things won't be in chronological but I will go back when I have time and edit the first post when necessary.
Here is my latest project.
Keith Knight
2,165
Wauchula, FL
CRUISE CONTROL and FOG LIGHT SWITCH install.
I started off by wanting to install 3 new switches in the dash For Cruise control and fog lights and ended with removing all the dash components, steering column and side steps for painting while I had it apart.
Here is the gage panel with 3 new holes machined into it.
Refurbished the light switch after finding some evidence of arcing on one of the terminals. Also found some corrosion on the circuit board.
Painted everything and reassembled everything.
Cruise switches.
Fog light switch.
Removed entire side step assembly painted and reinstalled. With the addition of rhino lining on the step/lid.
Next I need to take it to the Caterpillar shop for them to program the ECM and enable the Cruise control.
While I'm there I'm also going to have them reflash the ECM with the 330 HP program.
mkcoen
382
Spring Branch, TX
Looks great Keith! I'm not nearly that ambitious. I think I'm done with mine, other than finalizing where to mount the back up cam, for the foreseeable future. I'm going to spend between now and next spring enjoying the fun of driving it. I may break down and repaint next year but haven't decided yet.
Bobcat701
Autryville, NC
Excellent job, you have great skill. I have been learning a lot about mechanics ever since I got mine. I find it relaxing. Thanks' for sharing. \
Joe
Keith Knight
2,165
Wauchula, FL
I found the tab broken off of the drivers side air bag lock down the other day. Just one more repair LOL!!!
The broken piece is to the left in my hand, I made a new one and welded it on then primed it.
Keith Knight
2,165
Wauchula, FL
Thanks suprman, but I didn't do a good job explaining the picture. The broken piece is in my hand and the primed area is the part I made and welded on.
coachgeo
3,546
North of Cincy OH
How does the other cab shock housing look? Only mention cause if it has some tweak too; then consider with both being tweaked as a possible symptom of side to side motion of the cab your not suppose to be getting.
Keith Knight
2,165
Wauchula, FL
Along with all the fluids being drained it was also missing the batteries and the battery cover. Keeping with the thought of easy servicing I wanted to use a common battery. After doing the research and some measurements I decided to go with the more common battery and used 4 of the Group 31C batteries. Here is the result. In addition the original cables wouldn't work so I made the connections using silver plated copper buss bars from McMaster.
Battery bus bar2.jpgBattery buse bar.jpgBattery cover.jpgBattery hold down.jpgBattery tray.jpg
Keith Knight
2,165
Wauchula, FL
Finally had a chance to engineer and build a set of aluminum ramps for loading my jeeps into the back of my M1078A1. Here some pictures.
Its a 1995 jeep YJ on 37" tires. The total height is 11' 8". When loaded it lowered the M1078 by 1 7/8". The Jeep weighs close to 5,000lbs.
The Ramps are 12' long and roll into the bed.
