Key/ ignition cylinder?
Iamnewatthis
Dallas, TX
Key/ lock/ Ignition cylinder doesnt make good contact, i have to wiggle it and or hold it forward without going far enough to turn truck over. If i do, truck wont start. If i turn key forward till there is pressure, glow plugs/ wait light come on, then truck will start.
Anyone run into this before?
Warthog
228
OKC, OK
Your ignition switch at the bottom of the steering column needs to be adjusted. There is a sectinon in the TN that covers it.
The key/cylinder turns and pushes a rod that pushes the switch.
You may also need to replace the ignition switch. About $10 at the parts house.
Iamnewatthis
Dallas, TX
Oh man that makes total sense.
I replaced the ignition switch awhile back but i dont think the rod is right, i thought it was for the turn signal and ignored it.
I will take it apart and put it in right, thanks so much. I'll let you guys know.
Barrman
1,666
Giddings, Texas
The self cancelling turn signals are done by a plastic piece inside the column between the steering wheel and the lock cylinder.
