Knocking Power Loss
2INSANE
856
Belgrade, Montana
Hello! I have an 83 Gmc 6.2 diesel truck Civilian I just swapped a Cucv J code with new injection pump on it. Only 30,000 miles. Started knocking loud and loss of power. Happens when at idle while in gear. Any ideas will help?
cucvrus
10,501
Jonestown Pennsylvania
Are the transmission to engine bolts tight? Are the Torque converter bolts tight? That would create both issues. Have you checked the oil? I would check all the fasteners. These are my ideas from afar. Good Luck.
snowtrac nome
142
western alaska
check oil verify good oil and pressure look for metallic flakes in the oil the loss of a rod bering is enough to drop compression so an engine wont fire. if the engine is mechanically sound I would think it is a fuel knock the result of a bad injector. you can find which one by cracking lines until the noise goes away
2INSANE
856
Belgrade, Montana
I checked oil. Still super clean with no metal shavings.
I found the problem. It was a bad injector. When the motor was cold, I started it up, opened the hood and put my hand on the exhaust manifolds on each cylinder. Each one started to warm up except 1. I replaced that injector and filled the fuel filter with ATF and full bottle of Seafoam in the tank. The noise went away and I have more power then ever! Thanks again for all the help!
