- 3,343
- 2,249
- 113
- Pemberton, N.J.
I have to agree with Jeff, 14,000 lbs. is 3500 per tire and you will not find many 16" tires rated that high. I am pretty sure the highest rated axle I have seen with 8 lugs is 6000 lb. so you may want to check that axle rating. You are into the 14.5" tire size to get that kind of rating, or triple axle.
ON edit, I need to correct myself here. I just went to E-trailer and they list not only 7000lb 8 lug axles but also 8000 lb. 8 lug axles! Now where do you find a 4000 lb. plus 16" tire?
