- 7,066
- 166
- 63
- Mid Hudson Valley NY
It was easy to jackknife in the hands of not so well trained operators.
Couple of questions...CGarbee said:Not to hijack a thread... But if anyone is interested in the flatbed linked to in the first post of this thread, I've got one that is similar enough that it might be intersting, and I have a title for mine with no EUC required...
Photos are located at:
http://www.garbee.net/~cabell/photos44.htm
There are some ramps at a military surplus yard nearby that I have my eye on that look like they are made for this trailer... I figure that all it would take would be a piece of heavy wall tubing slipped into the holes on the lugs already welded to the end of the trailer to secure them (holes in the ramp end tangs are the same diameter as those on the trailer's lugs). That way, they could be flipped up and down or removed as needed as long as the tubing was secured with threaded end caps or pins to prevent it from walking out.rmgill said:If I understand right, that's an engineering trailer so it should handle some pretty heavy objects. I'd doubt if those fenders would have a problem with anything up to a few tons on them. Given how they're gusseted on both sides, I should think they'd do fine.
Adding ramps, weld on some hinge brackets and you're good. Though, were it my trailer I'm not sure if I'd want to add ramps or not. Removable units would be nice. I keep wanting a military trailer with a WWII look like this for my WWII mv transport.
Its not the sort of thing you back up. I did pretty well with the maiden voyage on the Deuce with the trailer not having to back up. It'll usually be pulling into places where we've got enough room to unload full sized rigs with tanks so, a bren carrier or something is easy. The advantage would be that ANYTHING military and of the right size can tow that trailer and drop it no problem since the towbar is pull/steer and doesn't hold any weight. If I really needed to back up, I'd use a front hitch and spot it that way.73m819 said:there was one of those at aberdeen, i bet it would be a REAL pita to back up, with that front steering dolly, i can see the 819 backing that thing up, would end up running over it before i got it where i wanted it
Including the concrete blocks?I need to be able to move this around
clinto said:Including the concrete blocks?I need to be able to move this around
It is for sale until somebody sends me some money..citizensoldier said:Well is that flatbed trailer still for sale? If so how much for it? That is just what I have been looking for to pull my M37 behind my M109 van truck. It looks plenty strong and I could build ramps very easy. Give me a shout at 1cu812@charter.net Please let me know either way.
They actually more then double for the M104 and M101 trailers and have a similar increase for the 1/4 and 1/2 ton trailers that I have in the back yard...rmgill said:Actually, I don't think trailers double weight capacity on road.
