Rattlehead
- 3
- 18
- S.E. Michigan
In a project that I have been working on, I needed a rubber grommet for wiring to pass through 1/4" thick frame. Not finding one at my local GOOD hardware store, I came across an option that can be found at just about any auto parts store. It is a PCV grommet from older Fords. It requires a 1" diameter hole, and provides about a 3/4" diameter pass-thru. It is part number 42049, often found in the HELP section.
