Got them off last night, Three foot breaker bar snapped them right off. I Found the cause of my fuel issue, vent tube was completely open to the elements, hose rotted through. PO must have messed with the tank at some point, they didn't do a good job.You tried heat and couldn't get the nuts off the tank straps? Cherry RED gets it every time. Good Luck. The tank straps are inexpensive. It don't matter if the are made in China or Katmandu. If they fit and get tight they are the right ones. Good Luck.
This place lists them might want to call and see if they still have them.View attachment 759168View attachment 759169View attachment 759170View attachment 759171 Some Pictures of sending unit and brakes. They were pretty badI want to replace the entire sending unit. The only units I can find are 3 hose. Is there a way I can rig it up to work or no.
The second link is the same one I picked up from napa. I'll have to check but I think it might work.This place lists them might want to call and see if they still have them.
http://www.flmv.net/FLMV-CUCV.htm
And here is a place in germany with them.
https://www.us-army-military-shop.de/product_info.php?language=en&products_id=4093
LMC shows them also . The 2nd link in post #67 is the correct part per the parts TM.The second link is the same one I picked up from napa. I'll have to check but I think it might work.
