- 2,479
- 24
- 38
- Houston Texas
I sudjested removing the intake tube at the turbo for a quick test drive. So he could see if he had a restriction. I don't think he does. I don't think 1150deg is anything to worry about. 600 deg while crusing is about right. Your highest temps should be at low RPM and alot of throttle. At this point you will have alot of fuel and not as much airflow. This will turn exaust black and send temps up. As the temps climb the turbo will acclerate and provide more air flow. This should bring temps down as the air flow increases. Unless you have a heavy load then you should see higher temps all the way to redline under WOT.
At a piont you will start to see higher temps because the more you comperss air the hotter it gets. Having charge air too hot will send temps up also. The intake manafold cools the charge air somewhat but there is only soo much it can do at higher boost pressures. Also this is a fresh engine right? out of the can? After you get it broke in things should change.
