M-61A2-OK so I am pulling my LDS out since it is pretty much shot. I am not replacing it with an LDT or an LDS and am going with a IH 6.9L IDI that is out of a 4x4 bus that is hooked to a spicer 4054D tranny. I found an electric motor and a steel plate and I am going to run my air compressor with the 12v motor 1/4hp and just run it remotely alone so that is not an issue. If it does come to be one I can always run an air ride compressor, but to the topic at hand. Since I want to keep the power steering but using the pump on the LDS is going to be a no go. The engine i picked up is complete with 160amp alternator, power steering, air pump, and all the rest of the goodies. This engine was running a 26' bus that was 4x4. My question is would the power steering pump that is on the bus engine be able to run the 5 ton steering system? I think its the same pump that runs an F-250/350 diesel as well. Does anyone know the amount of pressure the 5 ton system needs to operate? I know I will have to redo the fitting to make it work down to such a small pump hose.
