LDS vs LDT
gimpyrobb
dumpsterlandingfromorbit!
27,791
791
Cincy Ohio
LTD and the LDS is the same motor... swap out the injection pump and time the ip correctly.... vwala.. got yourself a cheap hi-po trick... eagle4g63 did the swap... the multi in that deuce ran like a rapped ape.... the TD on the right side of the motor means thick deck which uses a higher torque for the cyl heads...
Hope this helps...
Fixed it for you.
