LDS465-1C Injector pump
armyvet67
Bonaire, GA
I have a M35A2 that seems to have excess smoke at idle, but my fuel mileage is pretty good. I was wondering if there are any adjustments on the fuel injection pump that would reduce the smoke at idle? If anybody could help it would be appricated.
Thanks very much.
1,174
Black, blue or white? Hot or cold or all he time? Does it smoke under load at highway speed also? Have you driven it hard for atleast 45 minutes lately?
armyvet67
Bonaire, GA
I drive it about 55 each week. It smokes (Black) worst at cold idle. I think that it is getting a little to much fuel and or running a little (RICH). Are there any adjustments on the Injector pump for a little to much fuel? Thanks for your reply.
1,174
Yes, look at the "troubleshooting the lds" TM. Look at the droop screw adjustment(idle-1600) rpm, iirc.
You probably should confirm your IP is timed correctly also.
1,174
Oh, also check you air intake and filter. Make sure it's reasonably clean and no obstructions.
derby
S.E. MI.
With the LDS isn't it supposed to smoke alot? My dump smokes like an old steam train until you get up to speed and then it clears right up. and i get 7mpg:oops:
Flyingvan911
158
Kansas City, MO
That's what mine does too. The smoke at idle is white-ish blue. It does not seem to be loosing or making any coolant or motor oil. The smoke cleans up well at speed. Mine is a LDS465-1A. The C turbo sounds great.
1,174
Remember, the reason these engines/trucks went out of production was, they could not meet emissions standards. You can not expect them to burn clean all the time.
armyvet67
Bonaire, GA
Airfilter
I checked my air filter Doghead and it was the one on my truck when I picked it up at GL and it looked ok from the outside but for some reason the filter was old I guess and it was completely stoped up very little air flow. I installed a new air filter and my truck ran a lot better and has very little black smoke now.
Thanks very much for your help.
midcounty
26
Preston, MD
Hmmm, got me wondering if I should change my air filter. I looked at it when I got it home, and like you said it 'looked' ok. My gauge doesn't indicate a problem, but I do get alot of black smoke at cold idle. We just got our first cold snap last week, and it was a bit slow to start.
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
The appearance has little indication. I was using the filter that came with my M62 for years. When I decided to buy one at a "good price" so I had a backup, I tried it out on the truck and had a HUGE drop in EGTs. That original one is in the trash now.
midcounty
26
Preston, MD
Time to order a couple filters I guess. One for current truck, one for truck that is sitting on GL's lot, and may as well have a spare.
23st52
fargo nd
i need help from somebody that knows about injection pumps my duece was stuck from sitting to long before i got it so i had it gone though by a local shop put it back on and it ran for half an hour then quit took the pump back off and brought it in several times they have said now try this or it should be working we have followed the timing marks by the book but i have to be missing something
this last time that i got it back it smokes when cranking but does not fire the truck fires up and runs if you feed it through the intake so i don't believe that it is a motor problem
please i need some help on this one.
