LDT Engine Temp In 30F Weather
gimpyrobb
dumpsterlandingfromorbit!
27,787
778
Cincy Ohio
I have found the springs in the thermostat work great as a replacement spring for mounting the radiator(the 2 studs on the bottom).
74M35A2
342
Livonia, MI
I did not. I still have it even though it should be tossed.... but I couldn't be happier with the performance. Like any typical diesel, it takes a little while to warm up, but it goes to 180 and then just stops. Its beautiful! :D
You should throw stuff out immediately upon proof that it was bad. It prevents it from being stored for 3 years, unlabeled, and then re-installed and wondering why it doesn't behave. Above posts as reference.
If anybody wants LDx thermostats installed labor free, I'm apparently in the business of doing so and getting quite quick at doing it.
Wildchild467
59
Milford / Michigan
I was working on something else and you jumped right on changing it. I still say I over paid on labor though :)
