Leaf spring eye bolts ???
rustystud
3,133
Woodinville, Washington
FWIW, I would recommend changing the two bolts to studs, sold by a variety of suppliers.
Dana 60 ARP Stud and Nut
Would be worth the $20.00 cost.
Also consider, changing the Front Shackles to ORD Heavy Duty Version and use the Greasable bolt with nut that are available.
View attachment 632858 View attachment 632859
Compare front shackles ..............Greasable bolt
Regards
I just changed mine out last month. I did use the "ORD" kit. Pretty nice kit though one of the zirk fittings blew out when I was greasing it. I also went with the studs. I loctited them into place and after the springs where all mounted I cut the studs down to the proper length.
Drock
12
Eatonton GA
Regards
Do you have a link to those studs? I can't seem to find them online. All I keep finding is the studs for the high steer kits.
Drock
12
Eatonton GA
Okay can someone please help me find the torque specs for the leaf springs? I've stared at the TM's till I can't stand it anymore and still can't find them:shrugs:.
joshuak
215
Slower shore, DE
For the U bolt nuts? If so, TM-34. Step 11. I think has what you need.
Drock
12
Eatonton GA
Cool thanks for the specs guy's. However now I have a new problem. I just finished the U-bolt flip when I noticed I have a broken leaf on the drivers side. Where do I find a stock replacement set of leaf springs for an M1028???
Obijuank5
Central tx
Any 73-87 gm 3/4 and 1 ton had 56 rear springs. Very easy to find in the yards still. New replacements are also available. Your local spring shop will be able to rebuild your pack as well.
