Leak diagnosis
Suprman
654
Stratford/Connecticut
Hard to tell. Is that a gp pic? Does it say its oil? Are there engine pics? There are oil lines on the front of the motor. Front cover. Front seal. The list goes on. Need more info.
Dmoneygage
20
Maui, Hawaii
It’s an auction item. Can’t get them to respond. Seems like it originates past the oil pan somewhere up there. Hard to say with so little info.
Dmoneygage
20
Maui, Hawaii
1,168
Inspect in person.
Ronmar
6,629
Port angeles wa
That location on the driveshaft is directly below the Air Operated Pump... it is also directly below the PTO cover plate. The trans fill line also runs right over that location.
since this doesn't look like a winch truck, that cover might be loose, the fill hose might be split/cracked, or the AOP might be blowing oil mist or have a oil leak... Maybe...
Dmoneygage
20
Maui, Hawaii
Can’t. Quarantine
it is not a winch truck. Very informative. Thanks for the advice.
Suprman
654
Silly me. I misread. Thought you said front. ronmar is right. That is classic hyd fluid dumping. Especially if the cab isn’t folded in the pics. They tried to pump it and that was the result. Probably a bad seal on the cab latch.
Dmoneygage
20
Maui, Hawaii
Ok. That seems like an easy fix. Wish me luck.
