*** Title Changed *** The transmission is not involved with this issue.
I have a leak coming from the crimped part of the fitting (where hose slips over male fitting then a crimp from the fitting secures it). My question, any quick way to fix it without pulling it off and making a mess? Would trying to squeeze the crimp harder fix it or make it leak more? Here's a pic of the style fitting I'm talking about (not actual part)
Ok, here's the sober update! It is the hose for my speedo that is leaking. I did get it right though that it's leaking from the coupling thingy on the fitting (in red). The area in green has the presence of fluid but does not appear to have a big leak.
Heres a pic:
Should I replace the entire speedo cable? My speedo bounces all over so maybe the leak and the bouncing needle are linked to the same problem?
Heres a pic:
