Leak: Thoughts before degreasing and diagnose
Leonardo82nd
70
Edinburg Texas
Looks like TRC is still in business. I could not find the bulb cover on the drawing. Contact info here: https://tecrescorp.com/contact-us
After looking closer at Kurt's suggestion, I think I'd go with a Digi-Key order before calling TRC......
Thank you’ll , I went ahead with Kurt’s suggestion and a few from Amazon. I ordered a few extra (4) . Shipping and all was around $11 not to bad . I will post when they come in - let everyone know which work best.
Leonardo82nd
70
Edinburg Texas
People. I wrote you that it was a non stocked part. The fault indicator was a pluck and chuck item. No repairs. The red lens you bought might fit in the hole. Better use glue.
definitely planning on using glue on whichever matches best, already have it ready.
Thanks again . (y)
jamawieb
577
Ripley/TN
how have you guys removed these crimped lines?
I’m having some trouble at this point. I already removed allot of the other stuff. It’s Moving along well excerpt these.
Take a dremel and cut the metal crimp long ways. Then take a flat head screwdriver to seperate the metal crimp and pull off. Be careful not to cut all the way through the hose because you don't want to cut the brass hard line. Also take it off the fuel filter housing so you can work with it. For future reference, it's alot easier to pull off with the entire hose still attached.
Leonardo82nd
70
Edinburg Texas
Yeah all of the soft lines you have photographed need to go. You can go with the OEM Contitech stuff, or go with Gates 27000 1/8" fuel line (available on the spool at a lot of local auto stores). Use hose clamps wherever possible on the primary lines, and little zip ties up on the returns.
Edit: And definitely if you have the roof off to do the return lines, take the side panel off near the separator so you can attack it with minimal swearing.
I have a quick question about original equipment/ grounding the gen set. This weekend, I have a master Electirican coming to show me safety procedures and take a look around the panel for future interlock.
But, in the lead time im doing a little research thru TM, youtube and SS posts .
But, the (3) 3’ rods bolted to the generator frame - I assume are for grounding - along with 3 joints to connect the rods + and solid cable . The cable has two ends, one is open. The other has a “tab” or connection end. I noticed everyone’s post and videos always have colored flexible electrical wire
(not sure of the technical terms)
my question is , will he be able to utilize these fittings and accessories to ground my generator.
I also have an alternate slide hammer ground rod I picked up.
Messaging with @Guyfang , he gave me some solid advice . I only intend to use the units convenience receptacles for now .
Guyfang
26,513
Burgkunstadt, Germany
But, the (3) 3’ rods bolted to the generator frame - I assume are for grounding - along with 3 joints to connect the rods + and solid cable . The cable has two ends, one is open. The other has a “tab” or connection end. (You do not have to use the "Tab". Most people just remove it and stick it in the ground stud. The other end is help in place by the ground rod wire clamp. Correct. You can use a ground wire with isolation. The army rarely bought that. Bulk wire, uninsulated. ) I noticed everyone’s post and videos always have colored flexible electrical wire
my question is , will he be able to utilize these fittings and accessories to ground my generator. (Of course!)
Open to read comments
Daybreak
2 Star Admiral
1,522
774
Va
Howdy,
You would be better off going to a local hardware store and buying a 8ft ground rod. The ground wire can be any type. Solid, braided, bare, or covered.
NOTE: hooking to your house, your electrician will want 4 wires connected, and bonding strap disconnected.
Leonardo82nd
70
Edinburg Texas
Finished ☑! (Just Need zip ties) thanks for everyone for the advice on methods and techniques. A dozen toothbrushes and close to a gallon of degreaser (and stovebright). Some of my hose connections may be a little to long (first time doing this) pushing the hose into the plastic connections was killer at first (even with a little diesel) then I started wiggling pliers back and forth , that helped.
MEP803a new to me, is leaking diesel. I filled with a little diesel (all I had on hand)
hit the dead crank switch, turned the master switch & it runs nice . except it was covered in diesel after I turned it off. (oil filter side only)
I plan to clean her up and pinpoint the leak, thought I’d ask: Any idea of where the problem is coming from?
Also does anyone know where to get replacement light covers for the fault indicator panel ?
I have a few missing (see photo)
Ray70
6,921
West greenwich/RI
Looks great!
As an FYI, the Stove Brite paint needs to be heat cured by running the engine at temperature. It will not be very resistant to fuel spills or other chemicals until it is cured. The details are listed on their data sheet , but I learned it the hard way... so just be careful until you have a chance to run it for a while.
Leonardo82nd
70
Edinburg Texas
Looks great!
Ok thank you ! Much appreciated.
Leonardo82nd
70
Edinburg Texas
Looks great!
It sure doesn’t , this is the only line I did not replace. When I started the set I found a leak that just barely dripped onto the paint and took it right off .
5mm (3/16”)
9/16 wrench 🔧 to take off .
Guyfang
26,513
If you would look at the SMR code, you would know:
Item is not stocked. Order an XD-coded item through
local purchase or normal supply channels using the
CAGEC and part number given, if no NSN is available.
This is the tech data. Take it to a hose shop.
CROSS-SECTIONAL SHAPE STYLEROUND
THREAD CLASS2B 1ST END
THREAD DIRECTIONRIGHT-HAND 1ST END
INSIDE DIAMETER0 47/250 INCHES NOMINAL
TEMP RATING-45 DEG FAHRENHEIT AND 302 DEG FAHRENHEIT SINGLE RESPONSE
OUTSIDE DIAMETER0 1/2 INCHES NOMINAL
MINIMUM INSIDE BENDING RADIUS3 INCHES
CONNECTION STYLESWIVEL NUT FLARE 1ST END
END CONNECTION DESIGNSTRAIGHT 1ST END
CONNECTION TYPETHREADED INTERNAL TUBE 1ST END
BURST TEST PRESSURE12000 POUNDS PER SQUARE INCH
LAYER COMPOSITION AND LOCATION1ST LAYER BRAIDED STEEL WIRE AND 2ND LAYER BRAIDED POLYESTER CORD AND OUTER LAYER MOLDED RUBBER, SYNTHETIC
MAXIMUM OPERATING PRESSURE3000 POUNDS PER SQUARE INCH
NOMINAL THREAD SIZE0 219/500 INCHES 1ST END
SEAT ANGLE37 DEGREES 1ST END
HYDROSTATIC TEST PRESSURE6000 POUNDS PER SQUARE INCH
INSIDE SURFACE CONDITIONSMOOTH
MEASURING METHOD AND LENGTH16 INCHES NOMINAL OVERALL
PROPRIETARY CHARACTERISTICSPACS
THREAD SERIES DESIGNATORUNF 1ST END
Leonardo82nd
70
Edinburg Texas
Howdy,
This area is the source of my diesel leak. I must be reassembling this incorrectly, or it’s defective and been the culprit all along .
Any suggestions? I have two washers on the left side (is that correct) - does the direction of the orifice matter- I see an inlet on the connecting fitting .
