charlesmann
- 713
- 93
- Temple, Tx
I have 2 L/FMTV rims that is leaking, even with a new oring and wire brushing and wheeling the halves and fresh coats of paint. I ordered some tar caulk strips, which we use when installing windows in aircraft.
it took 6pc of caulk strips to go around oring and laid it between the studs and the edge of the oring and encircled the hole for the valve stem, which is where the two halves were not seating properly, causing a slight leak.
im sure other uses can be found, esp in a road side emergency. Just thought id share it with y’all.
