Napoleon_Tanerite
- 3
- 0
- Warner Robins GA
My M1009 is leaking AT LEAST power steering fluid sieve! It also appears to be leaking transmission fluid and my coolant is magically disappearing, though I haven't seen any evidence on the ground of it. Looks like some or most of the cooling lines going to the radiator seem to be the culprit, as they're all pretty wet around the joints where the metal transitions to the rubber hose. Any decent/cheap fixes you guys have found?
