Leaking trani fluid?
osteo16
583
Evansville, IN
Transmission modulator.. has o ring that might be leaking where it goes into transmission.. Can remove bracket holding it in and slide out to check/replace O ring.. looks like housing may be leaking though because of the bit of RTV smeared over it.. easy enough to get a new one and replace if need be.. someone else with a bit more knowledge can chime in..
Ocho
beerthirty
iowa
Ocho
I put the RTV on it. We were about 80 miles out in the middle of no where. It slowed the leak but assuming the housing is shot. I'll order a new one
