leaky front boot seal
timntrucks
Ponchatoula LA
i see a little leak coming up form the rubber seal on the front of my m816. looks like it would be easy to fix. anyone have some pointers and a source for the seals thanks in advance Tim
Scrounger
66
Southern, Maryland
If you remove one of the lower bolts that hold the CV bolt shield on and oil comes out that is a good sign that an axle seal is leaking. Not hard to fix, just everything is heavy and greasy.
acetomatoco
Remember that the boot is just a dust seal...keeps dirt and water off the moving parts inside.. If you have a liquid leak there are further problems like a clogged axle vent, overfilling of banjo, wrong oil, water in oil, overgreasing of kingpins etc... ACE
OPCOM
27
Dallas, Texas
I thought my seal was leaking due to an oily looking boot, but upon removing the slimy boot, it was only grease in there, so got off easy on that one. The oil was from under the truck, a leak of about 1 quart/1000 miles can make a very big mess.
