Leaky fuel line from tank to pump
chevymike
460
San Diego, CA
It is in a protected area so it wouldn't be damage. Could be related to helping keep the fuel cooler as inside the rails would trap a lot of the engine heat and could cause issues. Just a thought.
erasedhammer
58
Maryland
It lasted 35+ years. Do you want OEM stuff? I probably have it in my barn. Shipping is the problem. But really if it lasted this long it outlived it's expected life.
If you have a replace for that section of tube that doesn't leak, I will gladly pay for it and shipping.
cucvrus
10,048
Jonestown Pennsylvania
Take a few pictures of exactly what sections you need and we can go from there. I know the front section from the right wheel house to the pump. And I need to know what other sections.
erasedhammer
58
Maryland
It's the 3/8" piece that comes from the hose just aft of the transfer case, jumps to the outside of the frame rail, and goes into a junction block inside the wheel well just next to the front passenger side bump stop.
cucvrus
10,048
The line is like new. Very little rust if any. Still covered in Ziebart. From the brass fitting back is all you need? I compared it to the M1028 and it is the correct part.
