led dash bulb size
papakb
1,186
San Jose, Ca
LEDs are available in 10-30v versions that are usable in both military and civy vehicles. The BA9 refers to the base size which is 9mm in this case. The S or D indicates either single or dual contact bases. This same lamp is usable in the turn signal switch but I did run into a problem in an M151 where the socket was wired backwards and the lamp wouldn't light up. Remember that LEDs are polarity sensitive. 99% of the time the contact in the socket is positive and won't be a problem.
Your tail lights are BA15 based versions of the same lamp.
Kurt
KG6KMJ
Blackmagic94
9
Oro Valley/AZ
Thanks guys
So am I hearing this right that I can install a BA15S into the tail light assembly and thus wouldn't need to buy the mil LED housings to convert my m1102 trailer to 12 volt-24 volt hmmmmmm
Mjvaden
Madison ga
I got mine from Superbrightleds.com part number BA9S-G4-32-28VAC this is the Green bulb $2.98 each. I installed them in the turn signal control unit too.
they work great! and Like they say super bright.
sed6
OKC, OK
Great info, thx. Do they still dim with the dash dimmer?
Mjvaden
Madison ga
They Do still dim on the dash.
I had put led lights for the tail lights and front turn signal lights and they would not flash. I found out that what i needed to do to fix this was put a LED in the turn signal controller and that fix it.
