LED Headlights?
datadawg
Bucks County, PA
I don't know of any, but make sure they will work on 24V. I assume most would be designed for 12V systems. Other issue is if tbe LED puts out too many lumens, you may be blinding everyone. The 5 tons have headlights probably 2 feet higher than those on a regular car.
Bowmanvolfire
Wichita Falls/Texas
LED Headlights for the Deuce
Hello Forum:
We have a 1967 Kaiser that could use a little help in the headlight department. Does anyone have any suggestions of suppliers/manufacturers of LED headlight conversions?
Thanks very much.
John
BCVFD
Powershift
-7
Ca
I have them on my M931-A2. I got them from a member on this site. They were easily one of the best mods I did to my truck. Night visibility is SO much better! Not to mention, they look badass. LOL I also added route clearance lamps. Great for off road use (or to annoy friends).
Jeepsinker
329
Dry Creek, Louisiana
They are great if you get a good deal on them ( maybe $150-$200 per pair). They are not very reliable. I've been through several pairs in the past year and a half. It is absolutely imperative that you have good grounds for them or they will fail in short order. Drilling vent holes in the headlight buckets will help dissipate heat from the heatsink on the back of the lights, if not, they get no airflow and burn up eventually. The mode of failure is almost never that they just go out. Usually they start flashing bright to dim intermittently. Very annoying...
tim292stro
39
S.F. Bay Area/California
I like J.W. Speaker lights - twice what TruckLites go for, but IMHO a better beam pattern, better look, and they have a little internal fan that helps melt the ice off the lens (stirs the warm air inside the housing).
https://www.youtube.com/watch?v=ygvYo7Zjq1M
Oshkosh has been showing their newest truck with J.W. Speakers (they used to use TruckLite):
And Harley Davidson entered into a contract with J.W. Speaker for factory LED headlights (notice the HD branding in the face of the evolution lamp):
Like others have said, what ever you put in, keep it cool by circulating air behind the assembly - and spikes are nasty with these, if you can put in a TVS-suppressor on your headlight circuit, the headlights will thank you for it...
wilsonmotors
ennis,texas
I have the mil spec version of the jw speaker and love them! I have them on my m1009 and my m35a2 but I spent over a grand per truck!!!!!! But by far the best upgrade I ever made so far!!!!
infidel got me
32
Newberry, Florida
I purchased two round headlights from fleabay for around 60 bucks.
I think they were listed for an old vw bus, but any 7 inch round headlamp
should work. I then purchased 4 hella h4 heavy duty bulbs 24v 75/70 w
I think I have around 110 bucks in lights and three times brighter.
Not a led, but cheaper and better than stock.
Just another option for you- I like mine.
sandcobra164
287
Leesburg, GA
I got a good deal on a set of take out's. They have been on my truck since the 2010 GA Rally and are still working fine to this day. They are the older now Trucklite models and if and when they fail, I'll get another set to replace them. I had the pleasure of greeting the Rally attendees to their first glimpse when I came off the night trail ride years ago. They loved it and now more and more trucks are running them. They get my thumbs up and I have not modified my headlamp buckets. I did ensure the grounds are good. Less than an ohm of resistance in my case.
Woodsplinter
Phoenix/AZ
Wait- you spent $2000 just on headlights? Do they shovel snow or cook breakfast?
Boy, I thought adding A/C and a good set of safe tires to my deuce were my best upgrade- better go check my headlights now. lol !
Wish I had your budget! :)
gimpyrobb
dumpsterlandingfromorbit!
27,785
747
Cincy Ohio
Wow- a light bar that's worth more than the truck it's mounted on? Amazing...
I could have sworn someone just paid about $700+ for their rims to be blasted and painted, just for looks. An expensive light bar is worth it, if the owner thinks its worth it, just sayin...
tim292stro
39
Tanget but - I'm building an engine for about $15K to go into a truck I bought for $1.5K... After the fact it's always more expensive.
Back on target, headlights are like your #1 safety device after the sun goes down. You could have brand new tires (x6 on a 5-ton), new brake master cylinders, new brake shoes and hubs, all new stainless steel braided lines to the hubs - potentially thousands of dollars of PM hardware and hours of effort. None of that is worth anything if you never see that deer run out in front of you...
If you don't think the LED's are worth the money go for a ride in someone's truck who has them - it's an illuminating experience. :lol:
welldigger
15
Benton LA
I had my a3 wheels sand blasted and powdercoated. In my eyes that was an excellent $400 investment to have 7 wheels done. They coated them inside and out. This way I won't be fighting rust when it's time to install new tires.
They also look fantastic.
