Left front tire on M35A2 900x20s keeps going flat??
royalflush55
547
Reydon, OK
See if any of your suppliers can get Kleber or Michelin natural rubber tubes in that size. They are thick and nice. Next look for severe service tubes from Firestone. They are thicker rubber too. These are all higher but last so much better!
fasttruck
636
Mesa, AZ
Putting used tubes in ew tires usually doesn't work out as the tires stretch with use and expand. The tube of course also expands so when this extended tube is put in a dimensionally correct tire it folds or creases and will eventually fail on the creases especially if it old. Another problem with old tubes, which are usually found on trailer wheels, is that when the tire is disassembled from the rim you have to lift the valve stem to get it to exit the slot in the rim and then do it again when the tire is put back together so you have 2 chances to start a leak at the base of the valve stem.
