Left the ACC switch on, no room for running start.
1,178
Not safe indeed, I would not do that again. You may damage one, or all three of your batteries. You may also damage yourself!
1,178
So, is the truck at the paint shop? Did you get it started? I had trouble sleeping lastnight...
An AAR is needed!
fasttruck
633
Mesa, AZ
Has anyybody think of hydrostaic lock on this ? Leave switch on, electrtic transfer pump fills one cylinder in engine up with fuel, especially if fuel shut of valve leaks, crank engine over and break piston or rod in that cylinder when fuel does not compress between piston and head. And you thoughy alternators were hard to change out . .
rlwm211
Guilford, NY
Standard starting procedure calls for a short spin of the engine with the fuel shutoff pullled out before actually attempting to start the engine.
This was the topic of a couple of a couple of threads in the forum, and also a PS magazine article in the resources part of the site. By turning the engine over in this manner you find out quickly if you have hydrostatic lock.
RL
Even if your truck
frodobaggins
Ruston, La
How could this happen with fuel ? It's not going to push through the injector pump and do this.
