Lessons learned for oil cooler hose replacement
bkwudzhom
ga
Not long ago I decided to replace the weeping oil cooler hoses on the M1008. Instead of buying new ($30+ each!!)... I took them to my local NAPA store that builds Hydraulic hoses. They were able to cut off the old clamp and install fresh hose that was not likely to leak in a couple of years like the foreign made new parts are reported to do. At least that's what I thought. Not long after they were installed I was getting a leak that was spraying on the exhaust pipe under the drivers side. The hose was intact...however the metal line that connects to the bottom was against the huge brace that helps support the firewall where the master cylinder goes. Contact with the brace had worn a hole in it. I tried Dorman parts from the local parts stores....they didn't fit ..Woulda known that IF I had Looked it up on SS FIRST!!! The bends were not even close. So I got the new part from the local GM dealer..($65!!!!)....It fit but it still was rubbing. SOLUTION!!! 5 mins with the Die grinder created the space needed with room to spare. There is supposed to be a bracket to connect both of the metal pipes and limit vibration. Mine is missing so I took a piece of heater hose and zip tied it around the lower pipe then zipped the upper one to it. when running the movement was greatly reduced.It will work until I locate a brace to replace mine.
Figuring in the total time to make this simple repair/upgrade is around 1 hour. Hope these simple solutions save someone the trouble I had.
b4thundr
LaFayette, NY
I think I'm gonna remove my lines and Install two 3/8 pipe plugs in the motor. Honestly these motors don't work hard enough to warrant cooler lines at least in my book.
rsh4364
15
greensprings ,ohio
I have been thinking about going with 3/8npt to 10an fittings in block then 10an braided hose to 10an to 1/2 npt to a B&M 70266 cooler,even the civy units had oil cooler so My thinking is it is a benefit to our trucks.
b4thundr
LaFayette, NY
I would agree with you 100% if we were talking about direct injected turbo charged engine with more than 155 horse and 240 foot pounds of torque.
