m38inmaine
- 103
- 63
- Maine USA
Is it possible to bolt on a level wind from a 5-ton winch on to a deuce winch? There is one in a local yard and thought it might be nice to have.
This is what is on the cable drum on the crane on the m819Old post but; I've been flipping thru a tow truck cataloge recently and they offer two types of level winders. One is a flat plate that presses down on the spooled cable and the other is a bar with arms that is also pressing down on the spool. If the drum width matches or if it could be modified does anyone think this would be a bonus for keeping out the bird's nests?
I was just feeling out what you guys thought about installing the pressure plate type. Esp. for winding in when your are done, but I guess your best bet is to hook up to a tree or something and reel in to get your spool tensioned again with tight wraps.
Oh, and you will also lose a winching speed. When using the the level wind, you turn the winch reverse of what it would turn usually so that the cable, after the level wind, can spool on the drum correctly. So, that being said, you'd lose your low and high for in and only have reverse speed for in and low and high out.
